2000 s500 ball joints
Old Dec 13, 2009 | 05:23 PM
tg3509's Avatar
2000 s500
how to replaced lower ball joints
Old Dec 13, 2009 | 05:51 PM
MBtech1098's Avatar
10 speed bicycle
You will need a ball joint press, they make ones specific for benz, but a generic one will work with some minor grinding to it. You need to detach the lower control arm and press it out, and then press the new one in. If you did not grind the ball joint press enough or use the correct one you will need to R&I the brake calipers.
