engine oil level
Old Jan 23, 2010 | 04:15 PM
regalchef's Avatar
2000 S500
engine oil level
Can someone explain to me what engine oil level,not when engine on means on the dashboard display?? I just had an oil change and had 9 quarts of Mobil 1 put in.I'm wondering if maybe oil needed to settle after change and might be a half quart low.Would appreciate any input!! Thanks
Old Jan 23, 2010 | 04:43 PM
rondocap's Avatar
Mercedes S55 AMG
You can't check it when the engine is on through the display, you need to put the key in the ignition and to the last slot before it turns on.
Old Jan 23, 2010 | 07:29 PM
regalchef's Avatar
2000 S500
response
I'm sorry but I'm still confused!! I did that but no response on display. What is it trying to tell me? Thanks
Old Jan 24, 2010 | 12:51 PM
Quadcammer's Avatar
96 and 08 911 turbos
ok, drive the car until the coolant is at operating temp.
Shut down on flat surface, wait five minutes, turn key to second notch, scroll to oil level.
Old Jan 24, 2010 | 01:07 PM
regalchef's Avatar
2000 S500
oil level response
Thanks for getting back to me!!As you can tell am very new to MB but am learning as much s I can. When you say scroll down how do I do that?
Old Jan 24, 2010 | 02:45 PM
cameraman123's Avatar
2000 Mercedes Benz S500 Designo
It is in the dashboard display. Use the menu and up/down buttons. Scroll through with the menu button until you reach the odometer. Then using the up/down buttons scroll to the oil screen, be patient, and wait for it to read you your oil level.
Old Jan 24, 2010 | 03:01 PM
regalchef's Avatar
2000 S500
oil level
Thanks.I found it in the owners manual and did exactly that. Worked like a charm. only thing is it told me to reduce oil level.I guess I have to take nut off oil pan and take some out. Is this what I should do??
Old Jan 25, 2010 | 09:38 AM
G.Freeman's Avatar
2000 S-430
My 2000 S-430 is doing the same thing, tells me to reduce oil level. Had it serviced at MB 3 weeks ago.
Old Jan 25, 2010 | 03:44 PM
Corsa9000's Avatar
2004 S55 ///AMG, 2007 E350
MB did a Service B on mine too and over filled the oil, warning came on alerting me to this. Had to take it back and had them remove a quart via suction tube from the dip stick.
Don't use the drain plug under the car, too messy and hard to control how much you drain.
Old Jan 25, 2010 | 07:00 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Yes it takes 8.5 quarts not 9.
