Problems after Jump Start
Old Feb 10, 2010 | 05:52 PM
Corsa9000's Avatar
2004 S55 ///AMG, 2007 E350
So, the car was sitting for a few days, had to jump start it. Now I have two errors:
1. Pre Save (not pre-safe) Failure, see manual, nothing in manual
2. SRS not functional, visit MB
Plus:
3. Navigation is stuck, shows off-road, map stuck at HOME position
4. Rear Sun shade does not work
5. Dynamic seat does not work
Any guidance is greatly appreciated?
2004 S55 AMG
Old Feb 11, 2010 | 12:09 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Your owner's manual advises against jump starting a W220 - the reason is because of the kinds of failures you are having (some could be permanent damage, requiring replacement).
However, try this: Disconnect your battery; leave it disconnected for about 30 minutes. Then reconnect, and see if any problems went away, or go away after starting and running for a time.
Also see https://mbworld.org/forums/s-class-w...ml#post3682080 for resets you may need after disconnecting the battery.
Old Feb 11, 2010 | 12:30 PM
Corsa9000's Avatar
Thanks for your reply Skylaw. The owner manual has a procedure for jump starting which I followed and did not see anything about not jump starting a W220. Where do you see that in the manual?
Thanks.
Old Feb 11, 2010 | 03:42 PM
tusabes's Avatar
Mercedes
I wonder if those portable battery packs with the jumper cables are better than jump starting using 2 cars?? Seems it would give just enough juice without being excessive.
Old Feb 11, 2010 | 03:49 PM
Corsa9000's Avatar
The jump start cables from Michellin ($35-$45) seems to be best. It has a regulator unit that prevents surges and it doesn't matter which cable is connected to what port on each battery, the regulator figures it out. All cables are blue, no red/black at each end.
Old Feb 12, 2010 | 08:29 AM
Skylaw's Avatar
Thanks.
Hmmmm - I have to eat my words somewhat. My '00 S500 owner's manual had a specific warning against it. My '05 does indeed contain a jump start procedure with many cautions, but advises that it can be done.
Old Feb 12, 2010 | 04:39 PM
tusabes's Avatar
Mercedes
can you include a copy of the cautions? My 00 s430 simply says not to do it
Old Feb 14, 2010 | 07:45 AM
Skylaw's Avatar
tusabes,
You can download an electronic version of the MY'00 owner's manual at http://www.mbusa.com/mercedes/#/servPrtsOwnersManuals/ - and amazingly, on page 351, there are the jump starting cautions and instructions.
I say amazingly because I clearly recall that my print version for MY'00 clearly stated not to jump start the car because of risk of damage to electronic components. There were no jump starting instructions, other than "Don't do it."
I do not know why the print version differs from the electronic version, or when any revision to the manual may have occurred - but it does differ - and you have confirmed my recall (I no longer have that car or its printed manual).
You can also check the jump starting instructions in later models - the ones for the '05 are a bit more extensive than for '00 (among other things, instructing to be sure the two cars do not touch, and turning off all electrical consumers - absent from the '00 instructions, but good precautions). Manuals for '01 and '02 S-Class are not available on the site, but '00 and '03 and later are all there.
Old Feb 15, 2010 | 01:29 PM
Corsa9000's Avatar
Dealer has advised that Gateway Control Module on my car is fried. They are replacing it under warranty, $600 item.
Extended warranty is a good thing.
Old Feb 16, 2010 | 06:50 AM
Skylaw's Avatar
Thank you for that feedback.
Old Feb 18, 2010 | 05:28 PM
chibenz's Avatar
02 S500
Thats nice but what kind of extended warranty you have on your car?
Old Feb 19, 2010 | 01:47 PM
Corsa9000's Avatar
MB warranty with zero deductible.
Old Feb 19, 2010 | 08:57 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
Yor gatway could of been the problem the whole time... The gateway is you CAN data gatway so it could of fried out while it was parked and than drained the batt .. But glad you had the extended
Old Feb 22, 2010 | 01:54 PM
Corsa9000's Avatar
It is possible that the gateway was the original problem. But I am glad it is fixed and all is well.
I also learned my lesson, if you need a jump start, call MB Roadside Assistance , they will come to you at no charge, regardless of age, under warranty/out of warranty and get you going.
Old Feb 25, 2014 | 05:24 PM
dildil's Avatar
s55K / s550 4Matic / GX470 / A8L /
Hi im having same problem where is the gateway module located and does it require programing
