Squeaky belt when cold starting
Old Feb 24, 2010 | 07:51 AM
mbraz's Avatar
s500
The temperature has been in the high 30's each night this week. I have noticed my belt or one of the pulleys is squeaking. It does this until the car warms up. Any suggestions on a fix?
Old Feb 24, 2010 | 08:02 AM
tusabes's Avatar
Mercedes
its not uncommon at startup if it goes away. Try some belt dressing.
Old Feb 24, 2010 | 08:10 AM
mbraz's Avatar
s500
I've read mixed reviews of belt dressings on other sites. Isn't that a temporary fix that leads to a messy engine compartment? Is there a particular brand that you have used or recommend?
Thx
Old Feb 24, 2010 | 08:24 AM
cameraman123's Avatar
2000 Mercedes Benz S500 Designo
I have the same issue.... May be my tensioner pulley though
Old Feb 24, 2010 | 08:44 AM
tusabes's Avatar
Mercedes
yes its a temporary fix. and yes the dressing can fly around especially if you apply too much...
youll eventually need a new belt if its glazed.
If its only happening at startup and then quickly going away its not the tensioner. The belt probably just has moisture on it.
http://www.ehow.com/way_5764151_do-s...quealing_.html
if it happens all the time then it may be the tensioner.
Old Feb 24, 2010 | 05:30 PM
It happens all the way up to operating temp. Once at 80 for a minute or two it quits
Old Feb 26, 2010 | 01:48 AM
shellshock's Avatar
2001 Mercedes S500
Check the cooling fan. It's driven by a belt with the motor in the upper corner. Mine makes some noise when cold and the fan is running.
Old Feb 26, 2010 | 03:49 PM
Corsa9000's Avatar
2004 S55 ///AMG, 2007 E350
I had a similar problem with squeaking on a cold start, went away after 45 seconds. Dealer replaced the belt tensioner and belt, under warranty.
Old Feb 26, 2010 | 03:51 PM
wusty's Avatar
Looking...
You have to have the belt replaced. Happened to me. Loud annoying,embarassing sound. It's like $70 for everything at any Tire/Service shop or Mercedes. It will 100% fix the problem.
