Radio Question/Help
You can add a "Cradle Eliminator Cable" and a V60 Bluetooth puck to make your car Bluetooth capable if you wish. See post #3 at http://mbca.cartama.net/showthread.php?t=33872 for how (and more part numbers). The same information is available in the "How To Guide" sticky in the Audio and Electronics forum here, but the one in the link has been edited and posted more recently. It is easier to follow. It also explains that "blue label" thing a bit more.
Also, be aware that your car has linear amplifiers for each radio band, located in a bow ahead of your rear windshield and hidden by the headliner. If you are having the problem on just one band (AM, FM or weather), suspect a bad amplifier there.
If the problem is on all radio bands and all stations, suspect a disconnected antenna. It could be disconnected at the COMAND unit, or at a small box under the trunk liner on the right side.
