Strange engine vibration at park/neutral
Old May 12, 2010 | 03:53 PM
rondocap's Avatar
Mercedes S55 AMG
I have an 01 S55 with 133k miles.
The last 2 days, the temperature dropped to the 40's..and I've noticed the car is idling a bit rough on park and neutral, and even on drive at a stop light.
It seems like a heavier vibration, that vibrates the dash a bit. My motor mounts are good, recently changed alternator, so what could it possibly be? In the winter at a cold startup I had heard this sound before, but now it seems like it comes on a bit more consistently even after the car is at operating temperature.
Old May 12, 2010 | 04:28 PM
benzat17's Avatar
2003 S430
spark plugs? did you change that since its 133k miles?
Old May 12, 2010 | 04:35 PM
rondocap's Avatar
Mercedes S55 AMG
Yeah, Spark plugs got done already like 20,000 miles ago.
Old May 12, 2010 | 05:28 PM
slowsky's Avatar
2011 C63
I have the same issue but I have an 01 clk55. Did you change your transmission mount? Oxygen sensors? Maf? Air filter? Spark plug wires?
Old May 12, 2010 | 09:20 PM
rondocap's Avatar
Mercedes S55 AMG
Yep, transmission+ motor mounts, and oxygen sensors about 20k ago, and new air filters 15k ago. Never changed Spark plug wires though, just the spark plugs..
Could be a dirty MAF? Does it give symptoms like these?
Old May 12, 2010 | 09:49 PM
slowsky's Avatar
2011 C63
yes, it could, maf from autohausaz is cheap...check it out..
