S600 2001 ABC lights on... What gives?
Old May 26, 2010 | 12:33 AM
ANGMED's Avatar
S500 1997 + S600 2005
Angry S600 2001 ABC lights on... What gives?
What to do, how to fix it?
Bummer
Old May 26, 2010 | 12:40 AM
tusabes's Avatar
Mercedes
depends. It can be anything from a weak battery to bad struts or valve blocks or ABC pump or electronics etc....
does the ride height look normal , does the car lift and lower when the ABC button is pressed?
If everything looks normal, disconnect the battery for several minutes and reconnect. Then when you restart it, turn the steering wheel all the way from one end to the other, while in park, a few times to recalibrate it.
