please help...my 2001 s430 won't start
![Angry](https://mbworld.org/forums/images/icons/icon8.gif)
while driving my s430 all of sudden the battery light comes on it says visit workshop then other lights flash and all of a sudden the power steering goes out and the cars slows down and cuts offs and now it wont start it turns over but thats it...i spoke to a mechanic and he said he thinks the catalytic converter went out (clogged up) and because of that the engine isnt getting any air so it cause the car to shut down.....can anyone help me out....thanks in advance
2004 S55 ///AMG, 2007 E350
How old is the car and how many miles on it?
I am confused by battery light warning light coming on first, thinking alternator is not charging battery, etc. Does it crank or is it completely dead?
its turns over as if its going to start but it doesnt crank....at first i thought that it was the battery so i had it charged but the car still doesnt crank....it has 98,000 miles on it and its a 2001
So we know it is not your battery. If it is your Cat., I believe MB warranties it for 100 or 150K miles. You may want to check with a local dealer to see if they will cover it. This is not an inexpensive part. I would call and ask them what the warranty on a Cat. Converter is before getting into details.
Good luck.
Good luck.
Webb,
Considering that an internal combustion engine needs fuel, air and spark to run, it might be the fuel pump, coils, weak battery, Cat. converter to name a few. You can eliminate these possibilities one at a time by checking to at least hear if the fuel pump is running, check to see if the plugs produce spark, etc.
Easiest way is to get the codes the car has already generated but you need a Diagnostics System for that.
Charging the battery might not do it if the battery is bad.
You could call Mercedes Roadside Assistance and they can try a new battery. Its a free service, they will come out to your car, and you only pay for the battery if you need it.
I would get a brand new battery and try that first.
