2002 S600, oil found in sensors
Old Jun 16, 2010 | 06:05 PM
Thordur Raglin's Avatar
S600
The check engine light comes on steady , then flashes intermittently, we took the vehicle to a service center not a mb (closest one 800 km away)
the scan showed P0300 ,P0310, P0311 ,P0312, misfire codes for left cyl bank, no discharge or scorching in Left ignition module, oil found in front left oil pressure sensor right below coil pack and also back o2 sensor, it was suggested that the oil migrated through the engine wiring harness inside the insulation of the wires and into the plug. Remedy suggested ...replace the oil sensor and the o2 sensor and the engine wiring harness.Any help would be appreciated.The engine wiring harness is not readily available (from Germany)
