2004 S430 TPMS module
2004 S430
Anyone know where I can get a used TPMS module for a 2004 S430? I bought 4 new sensors thinking it was the problem since they haven't been changed. Currently, I'm still getting an error message after resetting the monitor. Also, if I get the module, is it hard to install myself? From what I understand the module is someone around the driverside footwell.....
2004 S430
I will try to reset the TPMS and it tells me the monitor is broken not the actual sensors on each tire. I even tried removing the fuse for the sensor yesterday and see if it would reset itself and it didn't. Each time i restart the car the message reappears after I hit the "R" button.
1 Post
2004 S500 & 2011 Mini JCW
I would go ahead and do a search on this site. I remember a discussion about TPMS sensors going bad that are on the car itself inside each wheel well, that may be how you find out where your problem is. I don't have any more knowledge or experience on your problem.
2004 S430
TPMS sensors inside each wheel well
Hi, I've already replaced each of the sensors in each wheel well a little over a month ago. I think it's the monitor itself that may be bad.
I've had the TPMS act up on me a couple of times and I started a thread on it. Turns out it was just one of mine going dead but it is well known that the module itself goes south too.
