Recent S600 purchase disaster
Well when I cut the a/c on hot air blowed. I took it back and of course they recharged the system only to leak two weeks later. I love that this car has rear power seats wow! you dont see them features in every car but damnitt they dont work neither does the rear cooled seating.
Moving on I didnt feel a need to get down on my knees to examine under car since were in the 2000 era and oil leaks are not common but damn she is a leakin and mobil 1 at that! Last but not least within two weeks of ownership I hear a rattling around 1800-2000 rpm right at the shift points and that doesnt sound good. I figure it must be maybe the torque convertor since this thing puts out near 600ftlbs and I feel the vibration in the gear selector. I took it to the dealer and they said its in the engine of course and that itll be around 6hrs diagnostic time and a new engine will be 30,000 dollars. Well at least they give a free rental maybe I should keep the car in the shop forever. can anyone make sense of this? plus the car has 95000 miles also and a washer resovoir leak.
help please?
As for the rattling, a torque converter won't really "rattle." Is it shifting okay? Is it slipping any? Is the Check engine light on?
The rattling sounds like a catalytic converter going out. One of my secondary cats started doing the same rattle as you described. I had an exhaust shop just remove the secondary cats and install a straight pipe in place of it. I don't have emissions testing here in my state, and there is no oxygen sensor after those cats. The car knows no different, and it's just as quiet as before with no more rattle.
The dealer is already pulling the "it needs a new engine" line? I find that hard to believe with not even 100k miles on her yet. You need to describe this noise better, or better yet make a video of it and throw it on youtube or something. It could be something on the belt, it could be the AC compressor, it could be a loose heatshield, a bad cat, broken exhaust brackets, etc. Generally engine noise would be described with words like knock, ping, tick, etc.
Getting the engine caught up to where it needs to be won't be a massive task really. You'll be spending most of your time on the suspension. But replacing everything that needs replacing with OE part's will last. You have to keep in mind those parts probably lived a hard life for seven years and nearly 100k. People are always complaining how troublesome airmatic is, but these cars are getting old now. Go buy a new Explorer and bet me money you'll have to be replacing suspension parts before 10 years/100k. The only difference with that is you can keep driving it with worn out parts.
An airmatic equipped car....not so much.And the ride quality is totally worth it. You try find a car that has a better balance of handling and control, combined with utter smoothness for under a MSRP of 150k from 2003. Not going to happen.
Good luck buddy!
I hope you can enjoy your w220 as much as I do mine. Hopfully you can get everything sorted out. Two turbochargers and 12 cylinders sound like a symphony at wide open throttle!
I would just keep topping off the fluid and drive it till the wheels fall off instead of putting it in the shop every week
Rule #1 of buying a W220 always get a PPI (preferably from a dealer with these complex machines) and a warranty whenever possible. If you can't run away very fast.
The first thing I would attend to is that oil leak. Go buy a pair of those ~$30 12,000 lb capacity car ramps, toss em' in the trunk, and go to the carwash with a pocket full of quarters. Remove that fiberglass front skid plate that's under the engine oil pan. (4 bolts, super easy to remove) and get under there with the wand and blast everything clean. Spray out the engine bay as well. Don't bother using the "tire and engine degrease" setting. It comes out at a low pressure, and I wouldn't want to get that stuff on my paint. Just use the high pressure soap and go to town.
Take care not to spray electronic parts at full blast. Just try to get everything clean under there so you can make a accurate diagnosis of where the oil is leaking from. You never know, it could be as simple as a turbo drain gasket leaking, or a valve cover gasket, for example. Worst case scenario would be if it is the rear crankshaft seal. That would require removal of the transmission to replace. Still not the end of the world though.
Just take it one step at a time man. And like aforementioned, if you're savvy at working on cars, you'll have a amazing feeling inside knowing you repaired/mantain a $130,000+ automobile.
Thanks Oilver! Whoops, forgot the 600 Comes standard with ABC.
I hope that is what's wrong for you as well.
Regards
nobody on the forum can tell you what the problem is, unfortunately.
not good...
the first thing I do when considering an expensive car is at least a pre-purchase inspection with cylinder compression tests.
good luck.
A guy tried to sell me a 2003 mercedes s600 on ebay around that time (blk/blk) with about 95k miles. I won it for $15k which was a great deal. When I met him in Atlanta (he was from FL), the car was a total POS. The inside stank, and the ABC light was on. I didn't buy the car, and drove all the way back to NC. I just hope that was not the car you got.
Even though the S600 is usually owned by a more affluent crown, someone can still tear them all to hell. Be careful!
If it is make sure it is fully insured and burn the ***** to the ground somewhere remote and report it stolen.
Not the smartest idea, but neither is buying a car without even a glance at the mechanicals, especially considering you admittedly knesit was expensive to maintain.
In would say GL, but you are way beyond that.
I expected the MAINTENANCE to cost more than normal but not to purchase a vehicle and within two weeks to have a major catastrophe it wasnt the car it was the previous owner or dealer to hold liable so yesterday I retained a lawyer to handle the case and no I didnt buy this car off Ebay and it was maintained by a local Mercedes tri-star dealership.
what a great thread.
you bought a 7 year old car with 95000 miles. Prepurchase inspection is essential unless you get a full warranty.
Im guessing you bought an as-is sale, so you must accept that anything which goes wrong youll be paying for. A few states have limited return windows for cars purchased from dealers, the lawyer will tell you if they apply to you
let us know what happens
