abc suspension stuck
Old Aug 12, 2010 | 10:43 PM
xliemx717's Avatar
ML63, e550 cabrio
my abc suspension is stuck up in three corners and down almost on the tire driver's front. system was working fine, raised up then only one side went down, raised back up all good, lowered and three corners stuck up driver's front lower. I tried to reset the system and it did not work and now the ESP and ABS will not reset. I ahve checked all fuses and relays, good. any clues? bad pump? blocked valve? really baffled because the ABS and ESP do not work at the same time. Is there a SAM that runs these three? taking the car to the dealer is really not an option as i live in Korea and they tried to fix something else and screwed up another part........
Old Aug 13, 2010 | 11:13 AM
ch33sehead's Avatar
2005 CL65 (current), 2001 CL600 (chopped)
How many miles? Stuck may indicate clogged valve blocks from dirty fluid. Try pushing on and shaking each corner of the car to push the suspension up and down. If anything you may need to change fluid and filter and do rodeo. Hopefully valve blocks are still good.
