L Rear Turn Signal
2002 S430
L Rear Turn Signal
2002 S430 L Rear Turn Signal (yellow light only) has stopped working twice. Previously replaced the yellow bulb and it worked fine after that.
Tried that fix again and it didn't work. Any suggestions (fuse, new tail light...hope not)?
Ensure that the contacts on the plastic bulb holder are making contact with the metal circuit grid on the back of the taillight housing, and correct by slightly bending the tabs on the holder out if that is the issue.
Could be your problem.
