drivers side door controls
Old Oct 26, 2010 | 01:33 PM
mikee3909's Avatar
2000 Mercedes S430, 2006 C230
I just got the windows tinted, and i got home and folded my mirrors in and they wont go out , i tried to pull them out manually to get them started and then push to out button , pushed it and they folded back in now both buttons fold in and on the same door the passenger side widow only goes down when you push up or down and the heated seat light was on when i picked the car up but the car was not on , also when up try to adjust the mirrors push up goes left , push down they move right , and trunk wont pop from door , didn't think much at first only problem i had was when you let the driver when down and then put it up it would stop half way then push it again and it would go up almost all the way and stop had to keep pushing the up button many times then would go up ,had this problem prior to tint, please help don't know what the problem can be
Old Oct 26, 2010 | 05:45 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
I hate to bring bad tidings, but the guy who tinted your windows was careless, got your door control module wet, and it may now be fried. It may dry out and work (unless you REALLY fried it trying all the functions while it was still wet).
If that's the case, the only fix is to replace it. The S-Class Encyclopedia sticky addresses this as well.
Old Oct 26, 2010 | 06:20 PM
mikee3909's Avatar
How do i find this info out and where do i go, also where can i go for parts i live in Dallas TX, thanks for helping Also what is The S-Class Encyclopedia sticky
Old Oct 26, 2010 | 09:13 PM
xexpo's Avatar
2000 S430 140k (07/11)
I am sorry for your troubles but I must admit, I've got a headache from reading your post.
Reading the Owners Encyclopedia at the top of the forum should help you some. As Skylaw suggested, wait for the stuff to dry a few days and see what happens. You could also do a reset.
Old Oct 27, 2010 | 10:25 AM
mikee3909's Avatar
How do i do a reset, and how will that help , is there a way to get the mirrors back out
Old Oct 27, 2010 | 11:03 AM
xexpo's Avatar
By disconnecting the negative terminal of the battery (it will require some re-sync precedures, available at OE on top of the forum)
Reset like that should clear some errors, but get things dry first.
I am not sure if you can fold them out without the aid of the mirror motor. I haven't checked this but it is possible that the mirror fold motor will only engage if the button is pressed. Gently try to fold out by hand, when you get to the full fold out position, the housing may not be locked at the full fold out position. Again, wait for stuff to dry out and try the fold out button.
Old Oct 27, 2010 | 11:12 AM
mikee3909's Avatar
Thanks ill try that , ill give it a few more days
Old Oct 27, 2010 | 02:57 PM
Skylaw's Avatar
I should have pointed you towards it better; sorry. I had just pointed someone to it with specificity, but it was in a different thread.
The W220 Encyclopedia is the "W220 S-Class Owners - Start Here" sticky, located at the top of the W220 forum. It has links to many helpful threads, categorized by type; hopefully, you can get the best posts on W220 problems by the most knowledgeable members from a number of forums.
Because MBWorld does not allow much time to edit posts, the original Encyclopedia thread became chopped up, and its organization was becoming lost. Therefore I posted it as a pdf file in one of the last posts in the thread (and also retitled it - a change I can't make in the original thread). Please scroll to the posts toward the end of the thread, and you'll find the pdf file (right now, it's at post #36).
As I update the document, I'll have to post the new ones further down the thread. Sorry for that. Wish MBWorld would allow editing for as long as posts exist; that works much better.
