W220 ESP help!!!
W220 ESP help!!!
Hi all, I have a 2001 s430. I was having aromatic issues so I decided to get my struts rebuilt and a new pump... I just put the pump in today and when I started the car I got the ESP and abs malfunctions... The car will only raise on the passenger side Any help would be great!
2005 S500 4-Matic, 1978 450SL
You're relatively new to the forum, so Welcome! Also, see the W220 S-Class Owners Start Here sticky and scroll toward the end for the pdf version. It deals with the ESP/abs malfunction.
To fix it, turn the steering wheel fully left, then right. The lights should reset.
You seem to have a problem with a ride height sensor that is not connected properly; if not, then with the valve block - or possibly with pressure hose connections. Who rebuilt your struts?
It's not a dealer but a local Mercedes and BMW shop, I tried that fix of turning the wheel but it didn't work, is there a way to check the block? Or maybe the airmatic ecu?
