both rear blinkers flash when only one side should?
Old Dec 1, 2010 | 04:59 PM
nandika's Avatar
hey
I've recently noticed that when i turn on signal blinkers to any one side (left, or right doesn't matter), it blinks correctly on the front and on the mirrors, but on the rear both side blinkers flash (like if I were using the warning blinker)...
what can be the problem? bad wiring? or programming?
** damn police just pulled me over again to tell me about this...
Old Dec 16, 2010 | 07:28 PM
Mbzdoctor's Avatar
e350
check all turn signal bulbs, make sure that a single filement bulb is not install in a dual filement socket. that would be the most likely cause incorrect bulb installed.
Old Dec 22, 2010 | 02:48 PM
ALLDATAdiy INFO's Avatar
Former Vendor of MBWorld
Mercedes
Also check the relay and turn signal switch.
Old Dec 22, 2010 | 02:59 PM
paulmerc's Avatar
2000 s320
hi sounds like relay,check your fuse and relay list to locate it,chould of got damp if fuse box was not closed proper!! good luck
