S600 Electronic System Going Nuts! Suggestion????
Old Dec 22, 2010 | 09:13 PM
dtrain77777's Avatar
'01 S600 AMG W220, '99 E320, '73 CL350, '03 GSXR 750
Hi,
It's been raining hard these past few days and this morning my 01 s600 instrument custer is displaying all sorts of warnings (abs, lights, abc, etc). Not only that my windows and wipers are working sporatically, my rear sunshade is up, stuck, and is making noises. Headlights and tail lights are flickering. It's going berserke. What should I do? Rain is schedule to stop in the morning. Should I wait it out? Should I do a battery pull? My lights are on right now. Suggestions? Thanks in advance.
Old Dec 22, 2010 | 11:26 PM
Quadcammer's Avatar
96 and 08 911 turbos
dollars to donuts your have water intrusion on your passenger side, which has caused your SAMs to get wet.
Do a search on clogged drain or wet interior.
You'll get more info then you can use.
Old Dec 26, 2010 | 05:44 PM
thanks! it is wet on the passenger side.
Old Dec 26, 2010 | 05:52 PM
rondocap's Avatar
Mercedes S55 AMG
Open the hood, and see if the drain that's close to the passenger side is clogged up. If there are leaves and things like that, it can drain into the inside of the car.
