03 Creaking from rear end
Old Apr 22, 2011 | 08:58 PM
chpsk8's Avatar
2003 S430 2008 GL450
So my 03 S430 started creaking from the rear drivers side this winter. Started when it was -20 out, and went away after it got above 0 so I chalked it up to cold weather. Well it's 50 out now and it's starting to creak again so scratch that diagnosis.
Any thoughts what I might be in for? I've sprayed some lube on everything I can see as far as joints and bits. I can't put my finger on exactly what is making the noise. Sounds like it's more in the suspension and not the airmatic. I'm thinking a dried out bushing. I'm not experiencing any clicking, so not a shot ball joint or tie rod.
Anyone have any ideas? I'm sure a visit to the dealership is in order, but I thought if anyone had a magic spot to lube I would try that before parting with my hard earned cash.
Old Nov 3, 2012 | 02:10 PM
elbe's Avatar
2004 S500; 1991 300SL
Any further conclusions or was the problem solved? I have bad squeeking in rear suspension, both sides. Tried lubricating all bushings but to no avail.
Old Nov 3, 2012 | 03:06 PM
chpsk8's Avatar
Ended up being two worn bushings. The fix cost me about $500 if I remember correctly.
Old Nov 4, 2012 | 10:29 AM
mrbobby's Avatar
2003 S500 4Matic (SOLD) + 2004 S55 (SOLD) 2005 CLK 500 Cabriolet 2008 S 450
Mine's being done tomorrow, both bushings drivers side. I ley you know the cost later.
