PAINT PROBLEM(REMOVED) FROM OVER COMPOUNDING POLISHING
Old Apr 23, 2011 | 03:30 PM
Msap's Avatar
S500
I was using a porter cable to polish my car and somehow over-polished it with too much pressure to a point that I think the base coat is starting to appear along with the clear coat around it. It's on the hood of the car almost near the front right headlight. The color is black paint 040. I'm outside of Philly in the Main Line area. I've included a picture so you can check it out. I'm considering buying some paint and clear coat from PaintScratch.com and try to spray over it. What are your recommendations and the best thing to do?
Attached Thumbnails PAINT PROBLEM(REMOVED) FROM OVER COMPOUNDING POLISHING-car-area1.jpg   PAINT PROBLEM(REMOVED) FROM OVER COMPOUNDING POLISHING-car-area2.jpg
Old Apr 23, 2011 | 07:05 PM
chpsk8's Avatar
2003 S430 2008 GL450
Wow, you did that with a porter cable?
What polish were you using and what color foam pad?
I wouldn't use the paint scratch paint on that repair. It works for smaller spots, but with that burn in the "field" it will take a pro to do justice to that repair.
FWIW I've used that paint repair base/clear with great success on small repairs like rocker panels and trim. Good color match, just hard to feather in accurately on a large panel.
Old Apr 23, 2011 | 07:12 PM
Das Geld 2's Avatar
SL55, S500
Too much pressure and probably a professional polish? You cant fix it with PaintScratch.com think of spray paint can paint jobs on toyotas
Old Apr 23, 2011 | 09:57 PM
Msap's Avatar
S500
I used Meguiar's M105 Ultra Cut Compound with a wool pad. To correct it I thought that a few quick spray from the aerosol can and the clear coat might be able to do the job.
Old Apr 24, 2011 | 12:04 AM
chpsk8's Avatar
Ok, that's classic wool burn. Didn't know a PC could generate enough heat to even do that.
Looks like your in for a respray on the hood. Shouldn't be too bad, $500 for a decent match should cover it. Lesson learned I suppose. Ditch the wool bonnet and get a foam pad, much easier to control.
Old Apr 24, 2011 | 01:53 AM
s5benzo's Avatar
W221 2013 S550 Rwd, W221 2010 S550 Rwd
+1 ! FOAM PADS ALL THE WAY!
Old Apr 26, 2011 | 02:51 PM
Msap's Avatar
S500
Anybody from outside the Philly area can recommend a dependable and affordable place or body shop to get a decent paint job?
Old Apr 27, 2011 | 08:18 AM
srknutson's Avatar
2004 S500 & 2011 Mini JCW
Agreed a professional respray of hood needed. Foam and forget the cutting compound. Very easy to burn with the set-up you used. Go the the web and watch a pro use PC.
