Torque converter plug in S600 2005?
2005 CLK500 cab, 2004 S600 designo mocha
Yes transmission oil drain plug. You'll probably get around 3-4 qts by draining this way. You will need the OEM transmission dipstick tool to make sure you get the right level. You have the 5 speed 722.6 transmission.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
1 Post
S500 1997 + S600 2005
Babyman... thanks for responding, however, I'm not sure your response addresses my question, which refers to a drain plug in the torque converter of the transmission, not to the drain plug in the transmission pan.
Gotcha, well there does seem to be a screw plug m10x1mm in the torque converter, part number N000000000884. Also with the usual copper washer N007603010100.
Does that answer your question at all?
