A/C delayed start?
Old Jul 21, 2011 | 02:09 PM
mmstidham's Avatar
2000 Mercedes S500
A/C delayed start?
I've searched and if it's been discussed, I apologize in advance.
I've noticed that it takes about 1 minute for the fan to start blowing. It works perfect but if I turn the car off, it takes another minute for it to start blowing. At first I thought maybe it was an option so that hot air was never blowing when the AC was selected but now I'm not so sure because if the air was cold when the car was shut off, it couldn't heat up that fast if I started the car again within 60 seconds.
Am I missing something or is there an underlying problem?
Old Jul 23, 2011 | 03:01 AM
AH1W-COBRA's Avatar
2003 S500, 03 C240, 03 E320, 03 tahoe
[QUOTE=mmstidham;4764285]I've searched and if it's been discussed, I apologize in advance. consider the age of the system and the complexity,ie dual climate control. if it works dont fix it. i will say that if you set it on the coldest setting it should display MAX and push air immediately.
Am I missing something or is there an underlying problem?[/QUOTE
Old Jul 23, 2011 | 03:58 PM
mmstidham's Avatar
2000 Mercedes S500
Originally Posted by AH1W-COBRA
consider the age of the system and the complexity,ie dual climate control. if it works dont fix it. i will say that if you set it on the coldest setting it should display MAX and push air immediately.[/QUOTE
Set on max, it does not push air immediately. It doesn't matter what temperature or fan setting I use, it takes about 60 seconds for the fan to kick on.
Old May 24, 2014 | 02:12 PM
robindbailey's Avatar
s500 w220
old thread, but did you get any joy with the aircon delay?
mine does it too (1999 s500) but the temp gauge and steering wheel adjustment dont work straight away either.
