19" AMG style Wheels by Powerwheels Pro $649
WHEEL SPECIFICATIONS
Offset: 32mm 810 style / 35mm 804 style
Weight: ~30lbs
Hub size: 66.6mm
Bolt Pattern: 5x112
Finish: 810: Gun Machined Face - 804: Silver Polished Lip
Shipping: $85
FITMENT:
C Class: W202/W203 (big brakes will need spacers in the front)
E Class: W210/W211 (stock fitment)
S Class: W220/ W221 (stock fitment)
SL: R129/ R230 (stock fitment)
E63 Style wheels:
SLR style wheels:
Offset: 44mm
Weight: ~30lbs
Hub size: 66.6mm
Bolt Pattern: 5x112
Finish: Hyper Silver
Shipping: $85
FITMENT:
C Class: W204
E Class: W212
S Class: W221
811:
http://s735.photobucket.com/albums/w...5102008163.jpg
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards. Obvious exclusion is curbing, denting or any other misuse that can damage or etch the finish such as use of strong chemicals in the cleaning process.
Manufacturing Defect Warranty: The wheels are made utilizing the low pressure casting process like OEM wheels do and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarrantied to fit on your car without vibrating or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience knowing what fits your car. If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements. So we focused on putting the synergies in place that allows us to offer that service.
You can always call us at 248 686 2035 if you have any questions.
Thanks for looking!
The 35mm offset would be too aggressive on your car. It can be done without any rubbing if you like that look.
We do have the 810 in 19x8.5/9.5 45mm offset that would fit your car perfectly for $649 plus $85 shipping
We do have the 811 in 19" staggered in 44mm with the AMG logo. The wheels are also TPMS compatible.
Thanks,
Vassili
