no sound
Old Aug 29, 2011 | 10:31 AM
gac's Avatar
gac
2002 S500 black/java/2011 Escalade (wifes)
no sound
Hey guys, after the storm we had I discovered I have no sound from the radio, and the cd, i checked the changer but that seems to be dead, the green light does not light up nor do the cd's come out. the radio does light up as does the nav. but no sound. any ideas would be appreciated.
Thanks.
also notice when i open my sunroof (pop up feature) when pulling button down it dosent close i have to slide button back, as if the sunroof was opened all the way.
checked the fuse near cd changer and under seat they all look good.
Old Aug 29, 2011 | 11:19 AM
Quadcammer's Avatar
96 and 08 911 turbos
You get any water in the car?
Old Aug 29, 2011 | 11:36 AM
gac's Avatar
gac
Oliver, No the car, trunk etc. seems dry,
Old Aug 29, 2011 | 12:39 PM
gac's Avatar
gac
I'm screwed!
Old Aug 29, 2011 | 08:47 PM
Quadcammer's Avatar
I had this happen once. After restarting, it was fine.
I hate to say it (as its generally a cop out), but try shutting the car off, lock it, let the can bus go to sleep, and try again.
You could have a break in your fiber optic ring.
Old Aug 30, 2011 | 12:52 AM
gac's Avatar
gac
Thanks Oliver, I did, i've been using the car all day. I re-set the sunroof and that works fine , but still no sound. I have an appointment with Lakeview Mercedes on the 8th but I'm hoping it will "fix itself" (wishful thinking!)
Thanks for your input will let you know what it was.
Old Aug 30, 2011 | 07:35 AM
DRTYLNDY's Avatar
I had the same no noise issue a few years ago with my 2000 S500. I ended up pulling the fuse for the radio and then putting it back in and the radio came back to life. Hope this helps.
Johan
Old Aug 30, 2011 | 10:19 AM
gac's Avatar
gac
thanks DRTYLNDY or anyone, Do you know where the fuse for the radio is? is it in the engine area or under the rear seat?
thanks again!
Old Aug 30, 2011 | 10:57 AM
Quadcammer's Avatar
prolly in the engine area. There is a fuse chart on benzworld in the 220 forum
Old Aug 30, 2011 | 08:45 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Also see the audio troubleshooting section of the W220 S-Class Encyclopedia on Benzworld. It's a sticky on the W220 forum.
Old Aug 31, 2011 | 08:05 AM
DRTYLNDY's Avatar
thanks again!
The fuse I pulled was in the rear under the passenger side seat. Good luck!
