Will a S65 engine cover fit a s600
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
engine cover=yes
cluster=depends, they are coded to the vehicle so if it is used, no unless someone can clear the vin. if new=yes, needs to be coded to the vin
W220 S65 AMG
Sure, the cover fits great on the S600... I had a 65 CF cover on my previous car.
The cluster you can not buy used, it won't work. I bought my cluster from AMG directly, they will need a VIN number.
I have a deal on a used one for $300 and it literally has about the same exact amount of miles on odometer. Off by maybe 100 miles. So I figured I would get it. Are you sure there isn't a way to make it work?
You can put it in and it would work however it wont display mileage. I have a used 65 cluster as well and tried it. it didn't work and you cant code it with the sds either. You need a new one or find someone who can erase the vin out of it. The mileage is not stored in the cluster either. The ignition switch is where mileage is stored and it verify's mileage with other control units to duble check it self to prevent theft
