Brake Switch
I have search around for these messages "ABS ESP BAS PLUS AIR SUSPENSION WARNING LIGHTS" for our w220 what I have found is some said brake switch is bad some said rear wheel speed sensor bad. Can any one of you tell me where is brake switch locate? something I might want to try because not that expensive. on the rear wheel speed sensor how can I tell which one is bad beside connect it Star Diagnostic? I want work on it this weekend. Thanks so much.
Before hacking the system, I would first get the scan codes read to confirm that its not something else that's wrong. Using the "red car" theory is not that relaiable
Good luck.
