S430 01 Double Din Dash
S430
Does anyone know if the dimensions in a 99-02 w220 dash where the COMAND goes is the same measurements as a 03-06?
The idea is to use the seperate pieces of the 03-06 to make a double din fitting to go into the 99-02. Ive seen existing kits but they are all cheap plastics and the one I have has cracked. Ive glue metal strips to the reverse side to prevent it from cracking more.
Anyways, if anyone knows it would be much appreciated!
Thanks in advanced!
Thanks in advanced!
I have an 03 Comand MOPF in my 2000 S430. You have to trim a couple small tabs with a dremel but thats it, it will drop right in.
s430 radio keeps muting on and off.
Anyone know how to fix the on and off muting of the radio...Changed to a aftermarket radio about 1 year now..Radio started muting on and off....
S430
If it's an aftermarket unit, u will need to refer to your manual that came with the unit. Did you loose power to the car? If not, assuming you dont have a code or know the code, you disconnect the power to reset it.
