Srs light on off
I've also got a message saying display unit malfunction but the display looks fine,it was replaced already under recall....
Ive recently done. The arnott airmatic replacement n put in their spoofer to get the error messages to clear...
Pls comment on what may be going on....
James...
I did however, read through the "S Class Owners Start Here" sticky to see if I could troubleshoot the SRS warning light myself before having the dealer replace the sensor.
https://mbworld.org/forums/s-class-w...tart-here.html
Scroll to the Electrical section and follow the link for SRS light in addition to using MBWorld's search feature to find some more easy/inexpensive options for the fix before the sensor replacement....
I would at least try to do the inexpensive troubleshooting first because the sensor replacement cost me $1k....
- Chris
Don't forget to check the passenger weight sensor connection under the seat; they can get grungy, and a simple cleaning with contact cleaner (available at stores such as Radio Shack) may cure the otherwise expensive problem.
maybe it will be a simple connector issue under the seat....not the steering wheel contact for the bag.....
tnx, will chk and repost on my findings....
james R
