ABC pulsation damper and Filter DIY repair
2003 C32, 2002 S55, 1999 SL500, 2004 S430
The suspension pulsation damper will cause a humming / buzzing noise when not working correctly.
See TSB Topic number LI32.50-P-048280 for more detailed information.
![](http://i69.photobucket.com/albums/i73/CarBizindio/PC300436.jpg)
Not every thing I do is according to the strict guidelines of WIS, so use my directions at your own risk.
Jack up front end. Find the 2 bleed screws on the LF and RF next to the torque strut bushing and bleed the system. Make sure you have the car secure because you will lose all suspension pressure after this is done.
![](http://i69.photobucket.com/albums/i73/CarBizindio/PC310463.jpg)
![](http://i69.photobucket.com/albums/i73/CarBizindio/PC310466.jpg)
Remove the pulsation damper. You will need a 24MM wrench for this, because of how the threads are welded to the unit you can't fit the wrench in every position. Maybe you can take this off with a oil filter remover?
![](http://i69.photobucket.com/albums/i73/CarBizindio/PC300438.jpg)
![](http://i69.photobucket.com/albums/i73/CarBizindio/PC300443.jpg)
This is a good time to change your filter for the suspension.
![](http://i69.photobucket.com/albums/i73/CarBizindio/PC300444.jpg)
The top is held on by a hook, remove by pressing down on the spring.
![](http://i69.photobucket.com/albums/i73/CarBizindio/PC300448.jpg)
My fluid was black so I pumped out what was in the res. try to be as clean as you can be.
![](http://i69.photobucket.com/albums/i73/CarBizindio/PC300450.jpg)
Fill up res to the engine off min/max, install filter.
I started the car and set it to normal height, check fluid level at engine on min/max. Raise up then normal 15 times if any major components were replaced while checking fluid level only when set in the normal ride height level. If you hear a hissing noise in the area where you installed the pulsation damper or in the rear of your car then shut it off and bleed at the same bleed screws.
I had the hissing noise so I had to bleed the system 5 times. I had no luck getting rid of the noise. I ran the rodeo and dynamic test along with testing the pump and other components and had no codes after I was finished.
![](http://i69.photobucket.com/albums/i73/CarBizindio/th_medium.jpg)
At the end the main problem of the humming noise is now gone.
Hey so did that hissing noise go away? Mine is hissing too, and I'm wondering if its the valve as well as the damper that needs replacement. Sometimes when the damper goes bad, the contaminates damage the valve too. Let me know if yours is still hissing, or if the ride improved when you replaced the damper.
The original loud humming noise made by the bad damper is fixed. I'm not sure if I had the hissing noise before because the humming was so loud. I still have the hissing noise after 100miles on the new damper. I need to bleed the entire system front and rear before considering the pressure supply valve unit / Ride control solenoid valve not working correctly.
if your going to replace the valve I would say replace the damper also, its not a whole lot of money and its a huge improvement on the internals of the damper VS. the original damper.
carbiz, does yours still hiss?
First I changed the pulsation damper (hissing started), then the other day I did the front valve block, front pressure reservoir, filter, and mine still hisses after bleeding...
2003 S430 4Matic
Have you replaced the fluid? You should replace fluid while pouring fresh one return should go to separate container until fresh one comes out. While doing rodeo, that way all old fluid will go out, and that helped me.
I still have the hiss. alldata said its a very bad noise and should not be driven. I've ran 2 rodeo's and a few thousand miles with no issues yet. I just think its a matter of how many bleeds front and rear are you willing to do, its a real pain if you dont have a proper lift.
'96 SL600, '05 S55 AMG, '06 C230
Cheers,
Jeff
2003 S430 4Matic
I would say a quart every 20 seconds, at the same time I replaced the pump too, I had enough fluid to add so I stopped when fresh one came out. I stopped rodeo when fresh one came out, nice and clean. And that also stopped lowering itself overnight when fluid flashed. It was quite easy because I had a help, I controlled fluid flow he operated functions with scanner.
2003 S430 4Matic
I have replaced another dumper today for a friend. The easiest way I think is to check that pressure in the system is 0 using diagnostic scanner. Then take dumper off of valve unit slowly and only minimal fluid loss will appear. Then put new one back. Add fluid between lower and upper mark on dipstick and run rodeo to the point no bubbles appear on dipstick. Make sure fluid level is correct. No noise and no other problems. Nice and clean. But we did not change the fluid.
Just did the abc fluid flush today with a friend at his shop.
Followed exactly the steps on another thread under s55 forum (s55 diagnosed today) . VERY ez job, did not need to connect to a computer system.
Total 10 liters should be more than enough for the abc system (very clear fluid come out). Flow rate about 45 sec per liter.
Cheers,
Jeff
I would very much recommend the flush. I never flushed the system but I changed the fluid for the 2nd time out of the Res. It was almost as black as the first change.
2003 Mercedes-Benz S500, 2002 Acura MDX Touring
I think that number comes down to how good you want the exiting fluid to come out looking like. This number will change depending on your current fluid condition and how picky you are on the end result color. I'm not sure if it was mentioned or not but you should pump out the old fluid in the res and refill before starting the flush in order to conserve the amount of new fluid.
In my research of the ABC Fluid Flush, I asked my local MB Dealer what their thoughts were. Surprisingly (perhaps not), they also recommended 10 liters of fluid. Their work flow is identical to all discussed in this thread (remove ABC return line, drain/refill ABC res., run 'rodeo', etc.); just they would use 10 liters of fluid. Personally though, I would be shocked if anyone - even the dealer - would seriously require more than 5 liters, especially if the fluid is any reasonable color. If the fluid is truly black, then maybe 10 liters should be considered. But if that is the case, I'd be looking for something that is causing the discoloration. FWIW.
Cheers,
Jeff
Cheers,
Jeff
W220 S65 AMG
Fantastic write up! Thanks so much.
Few questions - did you notice the humming was especially loud when in reverse gear? Did the ride quality improve with the new bumper?
I can feel a very slight change in higher speed handling, but the major plus is not having that loud humming noise. The humming noise was rpm specific, I didn't notice a difference with reverse vs drive.
Humming and buzzing...on my 2003, S500
I cannot see the pics. SO would you please e,mail them to me @ steadystud73@yahoo.com ???? Also I see that my car has slower speed... due to this.. Is this because the Engine mounts (MB claims to be so) are bad?? would that cause teh humming/light groaning noise??
Thanx..
