Airmatic problems
Old Feb 4, 2012 | 11:21 AM
Ajagg's Avatar
2002 s430
Airmatic problems
After seen my 2002 s430 getting lower each morning after about 7 days it sitting on the ground one morning. With info from you guys I used soapy water to check the system for leaks I found that the air pump and the valve block above the pump was leaking. I replaced both part DIY . The pump comes on when I start the car but its not rising. Any suggestions Thanks
Old Feb 16, 2012 | 03:34 AM
alkemist's Avatar
W220
Were you able to check the components you replaced for leaks? Was the pump you installed new? Correct Part Number?
Old Feb 16, 2012 | 12:34 PM
ALLDATAdiy INFO's Avatar
Former Vendor of MBWorld
Mercedes
Have you checked the system again for leaks or faults?
