Cruise Control
I used cruise control and set it at 40MPH, and as I was going down a hill, I could have sworn that the car applied the brakes automatically to slow the car down. I saw the speedometer needle go to about 44MPH and it went back down to 40MPH after I felt the brakes being applied. Is this what cruise control does automatically or anyone else experience this before? Just curious...
But Mercedes Cruise Control seems to be different. Its for speed limiting only. it even have “Lim” written on it, right?
Well… you can set the max speed you want. So when you take ur foot off the gas, the car will decelerate normally. But when you step on the gas, ur speed wont exceed the on you chose on the Cruise Control.
Yes, it will apply the brakes. Though I think it should’ve been through the engine or something instead of the breaks.
I find this Cruise Control too useful when I drive on the highway here. We have a lot of speed limits cameras and its really annoying trying to slow down and make sure u’re not driving ove 120km/h not even one kilometers faster!
Too bad it doesn’t function correctly anymore
Its on a stick mounted on the steering colum
Push the stick in and it will limit your speed to that level it works in 5mph increments and you can adjust up and down using the stick, a little light on the stick lets you know its active, the car will not go above that level unless you kick down, it appears to brake to maintain speed.
Push the stick up and you set cruise control this works in increments of one mile per hour, once set you can remove your foot from the throttle, continue pushing up the stick and the car will accelerate, push down and the car will decelerate, touch the brake and you disengage it.
If going down hill and your speed exceeds that set by cruise control it will cut power and does seem to brake as well.
Have a look in your drivers manual
