Rear A/C
Old Jul 4, 2003 | 03:46 PM
PL599's Avatar
2002 S430
Rear A/C
Hi Everyone, My 2002 S430 seems a bit weird. When I set the fan speed to the MAX the rear doesn't seem to be blowing at all. Does anyone have this problem or is this normal?
Old Jul 5, 2003 | 12:58 AM
Crankin's Avatar
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
Do you have the optional rear AC system with its own controller?
I don't and the front AC is pretty good, back is a little weak, but I have to check to see how the back vents are set. That helps to set the vents correctly to blow maximum air.
I have an early 2000, which is known to have weak AC systems. Mine isn't bad enough to have MB tear apart the dash and put in upgraded controller, compressor, and posssibly create new problems, squeaks and rattles. And I'm in FL---HOT!
Old Jul 6, 2003 | 01:53 AM
PL599's Avatar
2002 S430
yeah I don't have the optional climate control for the back. And when it's I turn it FULL BLAST the back are soooo weak that you can barely feel them.
Old Jul 6, 2003 | 10:41 AM
Crankin's Avatar
a 2002 definitely shouldn't be that way. I would get it checked out. And maybe check in the owners manual to see if you have the vents set right. I find that setting them to the position of 1 square marker provides more air than the setting with 2 squares. good luck.
Old Jul 6, 2003 | 10:23 PM
ano0oj's Avatar
09' 335i coupe
in my 2000' s500, the rear a/c is weak, but the front works fine, next time we service the car, im gonna mention it!
