Can't play copy version of navtech disk...
Old Jul 14, 2003 | 02:58 AM
LuckySeven's Avatar
It seems like everyone can play copy (burn) version of navtech disk except my car. Can someone tell me why this is the case? I have a 2000 S430. The copy disk is valid because it plays in my friends car.. Thanks
Old Jul 14, 2003 | 03:22 AM
apricotscrub's Avatar
i got someones cd-r of a 2002, works, make sure you have a 00-2002 map not a 2003 map.
Old Jul 14, 2003 | 12:01 PM
LuckySeven's Avatar
Thanks for the comment apricot but the disk that i had was 07/2001 so it should have worked.. any other reason why it don't work?
Old Jul 14, 2003 | 12:44 PM
ok, this may fix it, ask your MB center to check to see if it got the firmware update, most cars have gotten it because its a service campaign they do to all cars, they have access to your VMI, give them your VIN.
Old Jul 14, 2003 | 02:09 PM
awiner's Avatar
2003 CL55 AMG
LOL. Dealers never just do a COMAND firmware update as part of routine campaigns, unless you complain of symptoms that the updates fix. And even then they give you a hard time and tell you they never heard of any updates.
Old Jul 15, 2003 | 07:03 PM
TGIF's Avatar
I had the same problem and this fixed mine. Disconnect the battery terminal and wait for 1 minute. Then reconnect it and reset the stereo code numbers. You may also want to spray some compressed air into the slot to clear out any dust. Good luck
Old Jul 16, 2003 | 01:28 AM
LuckySeven's Avatar
How do I know what my stereo code is for me to reset? Is it in my car somewhere or do I have to get it from the dealer?
Old Jul 16, 2003 | 02:01 PM
jutch's Avatar
MB s430
There are two versions of the Nav disk for model year 2000 according to my service guy.
Old Jul 16, 2003 | 07:27 PM
TGIF's Avatar
stereo code
The stereo code should be included together with the owner's manual. You should find a credit card sized card with the stereo code printed on it. Your friendly neighborhood MB dealership should also be able to provide it to you. Good luck
Old Jul 17, 2003 | 12:39 PM
LuckySeven's Avatar
Radio code
Just called my dealer... they said 2000 model did not have a radio code... is that true?
Old Jul 17, 2003 | 05:15 PM
TGIF's Avatar
Radio code
If you dont have a radeo code, then you don't have to worry about it then. They probably they took that feature out because too many customers were calling the dealership for the radio code especially since MB is now owned by Chrysler. I hope they gave you the Bose system instead of the AC Delco. In anycase, follow the instructions and hopefully that resets the radio. Good luck
Old Jul 17, 2003 | 06:29 PM
Ted Baldwin's Avatar
300ce
................The Comand system does not have a radio code.
Ted
Old Jul 17, 2003 | 06:31 PM
300ce
............I agree completely. Had the same argument with RBM of Atlanta. They were stupified. Had no clue what I was talking about and I the end, I did not get the firm update.
Ted
