Air Suspenion Problems
1 Post
2002 S430
I know this subject has beaten to death but here is my problem. I have a 2002 S430 and I am having Air Suspension issues.
The car has had a very hard ride for about 1 ½ years now but the dealer said it was fine and it should be that way.
I went in for an oil change about 6 months ago and the dealer said my front struts were leaking and need to be repaired with the kit. My car doesen’t loose height or air over night and I did the soap water test on the strut tops with no signs of leaks.
After the visit I would get low car stop warnings after 15 mins of driving only on very cold mornings. But if I stopped the car and turn it on and off it would run fine.
Now last week it was completely down and I could hear the air pump run and it would not rise.
I replaced pump with a new Arnott air pump and car works fine.
Except still a very hard ride.
Now the latest, last night on way home from work I pressed the Suspension button on the dash to firm up the suspension and with both red lights on and a 10 mile ride I got the car too low warning again for a split second when I stopped at a stop sign and then car raised by itself and all is good again no warning.
What should be my next plan of attack? Should I replace the Air Suspension Valve assy?
