S500 Water Pump Replacement
OK, so no one could help me with a procedure to replace my water pump, but the pump was shot so I had to get this done without much information. I recorded the process I used for future reference. here is a pair of pdf files with pictures and my notes. I had to break this into two files to upload due to the file size limitation of this site. Hope this helps someone.
Thanks for your excellent instructions. I saw your question about the serpentine belt and I did find the easy way to put it on and take it off. Once you have cranked the tensioner to reduce all of the tension, there is a hole that lines up with the engine that you simply place a rod through to hold the reduced tensioner position... I used a 3/4 rachet extension or a simple screwdriver of adequate length. This makes it super easy to work with alone. Hope this helps for the next time you work on the car.
nursenate
