PSE problem on 2002 S430
Old Nov 26, 2016 | 05:19 PM
cactusmike's Avatar
2002 S430 and 2013 S550
Nothing works on the pneumatic system except the trunk CLOSES with the door switch or the trunk close button. Trunk will not open except with the key.
The doors locks, lumbar, headrests, etc. don't work.
I hate to replace the whole PSE without knowing more.
Can anybody advise? Thanks.
Old Nov 29, 2016 | 10:18 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W220 forum...
Old Nov 30, 2016 | 01:49 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
I agree with Plutoe. Don't throw money at parts until you have a diagnosis done.
Old Nov 30, 2016 | 08:27 AM
wallyp's Avatar
2003 S500 2007 GL450
Have you removed, checked and replaced the yellow 20-Amp fuse behind the right rear floor lamp?
Old Dec 8, 2016 | 03:44 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
I fixed my 2003 s500 with pneumatic close assist by disconnecting the negative battery cable after checking the fuse, headrest drop feature and four doors work fine. the trunk however stops working every few months and I must reset again. i do hear five seconds of air before the handle pulls in so I think my vacuum vessel on the trunk latch is starting to go. I have heard of others who took this out and epoxied the ports, will likely be trying this next, good luck!
