sunroof configuration
hope thats what your looking for.
You can probably feel when you push the sunroof switch in the SLIDE OPEN direction (toward the back of the car) that there are two positions.
When you hold the switch half-way-back, the sunroof will keep moving until you let go of the switch.
When you push the switch all-the-way back as far as the switch will go and then let go, the one-touch-open feature should make the sunroof slide all the way back to the position it has memorized. If you try this and it doesn't go very far before stopping, you just need to resynchronize it to make it go all the way open.
Read through your owner's manual under the "resynchronizing" the sunroof and you will see an explanation. It goes something like this...
You clear the old memorized position by closing the sunroof all the way. Then push UP on the switch and hold it for 5 seconds in the TILT UP position, then pull the switch down (and hold it) in the CLOSED position for 5 seconds.
Then, the first time you hold the switch in the Half-way-back position, the window will start sliding back, and when you let go*, it will memorize this new position as the one-touch-open limit.
(*it's sort of like that...It could be that instead of letting go to set the new spot, that you push it to All-the-way-back position and THEN let go to set the new spot.)
There are also numerous posts in this W-220 forum on the same subject. Good luck.
