Mirror problem
Old Feb 28, 2013 | 08:01 AM
FrankBoni's Avatar
2005 S500 4 Matic
Mirror problem
Team,
I have a 2005 S500 4matic. 2 days ago before my oil change my right side mirror used to go down when in reverse.
The option is selected so it does this
The button is pressed for this to occur , on the drivers side door
The mirror does move manually in all directions
The mirror also moves slightly when put in reverse, just not downward as it used to.
Any ideas?
Thank you
Old Feb 28, 2013 | 10:28 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Try folding your mirrors all the way in and then fold them out again. If that doesn't work you can use your steering wheel buttons to scroll through the settings on your instrument cluster that allow you to turn the "reverse mirror" function on and off. Make sure you have it turned on.
Old Mar 7, 2013 | 03:26 PM
pjkwong's Avatar
S500
mirror
i'm not sure but i also have the adjustment button push down on the right mirror
