S600 V12TT Intercooler Coolant??
Old Apr 18, 2013 | 04:31 PM
marktan's Avatar
2005 Mercedes S600, 2004 Mercedes E500 4-Matic, 2002 Mercedes C32 AMG, 2001 Trans-Am WS-6
Does anyone know what coolant fluid to use for the M275 V12TT intercooler circuit? When I looked, it seems to have a bluish tint to it (like watered down windex). I have an Johnson CM30 pump I wanted to install, but wasn't sure what fluid to use. Tips?
(on a side note, has anyone installed a second coolant pump in-line with the existing stock pump, but put it on an "always on" circuit so it's constantly circulating, rather than the stock "turns on only when it's hot"?)
Thanks!
Old Apr 18, 2013 | 05:06 PM
terrance21!'s Avatar
Mercedes Benz G550
Please be sure to have a detailed write up of the install. I hear that the stock pump last between 40-60 miles and robs you of at least 30hp? Not sure if this is true or not but I would love to see a full write up for us "Newb Members" to follow. thanks
*Correction Junior member! lol
Old Apr 18, 2013 | 10:23 PM
Astro14's Avatar
Veteran: Navy
2005 S600 2005 SL600
Sounds like the new fluid from MB (which is blue in color, vs. the pale yellow of the old fluid). Same stuff that's in the rest of the cooling system...
Old Aug 17, 2015 | 10:50 PM
HRHohio's Avatar
C230k, ML350, and CL600
I'm also wondering. Can anyone confirm what the fluid is?
