Muffler delete
Old Apr 20, 2013 | 08:48 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Muffler delete
Oh why, oh why did I wiat sooo long to remove the mufflers from my S. This is the best $100 bucks I have spent in a LONG time. Car is just a little more throaty. You can notice it a bit at idle. And my favorite part was coming home form the shop, I actually had a flagger in a work zone give me the slow down sign. There were cars in front and behind me
I'll post a vid later.
If you own a 600, do it my friends.
Note: I think I will leave the cats alone, as I feel ity would make it WAY too loud for this type of car.
Resonators and mid pipe next weekend
Old Apr 20, 2013 | 12:21 PM
MB_Fahrer's Avatar
Deleted
Please do post a video. I was just looking at the Meisterschaft GT setup for my 600...
Old Apr 21, 2013 | 05:07 AM
tusabes's Avatar
Mercedes
Resonator delete is enough sound for me . Never seen a muffler and resonator delete !!
I agree to leave the cats
Note on turbo cars there is already some exhaust muffle from the turbos - the normally aspirated cars would be extremely loud with no mufflers
Old Apr 23, 2013 | 11:53 AM
Dr. Tune's Avatar
2003 S600
Question is, how does the sound compare to a cat & resonator delete while leaving the stock mufflers in place?
Second question is, which actually makes more power?
My thought is that deleting the cats would do more for improving power as the exhaust gases are much hotter up front and therefor the cats should pose the biggest restriction if any.
Any dyno pulls, before and after out there?
Old Apr 24, 2013 | 06:45 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Deleting the mufflers does NOT give you anymore HP, just a nice throaty little grumble.
Deleting cats has shown to give a good gain, at the cost of ALOT of noise. Not my choice for an S, IMHO.
Resonator and midpipe delete has shown gains, IF you make it a true 3" duals exhaust.
That is my next step. I have a before dyno, so I'll post an after, once I get my true duals.
Old Apr 24, 2013 | 09:40 AM
Dr. Tune's Avatar
2003 S600
That has been my experience with many other vehicles, but since I haven't tested the S600 exhaust system I didn't want to ASSume.
Generally mufflers control noise without much restriction, while the cats could create a restriction/reduction in velocity of the exhaust gases.
So your combo is no cats and you will be installing true 3" duals/deleting resonators and keeping the stock mufflers?
That's what I thinking of doing as well. Are there any video clips out there of this combo?
Old Apr 24, 2013 | 12:02 PM
MRAMG1's Avatar
S600, GL450, GLC 43
No my friend, as it stands as of today I have cats, factory y pipe, resonators, and no mufflers. I am going to remove the factory y pipe and resonators with TRUE duals in 3".
For me, the removal of the cats would also remove the elegance of an S. After all, this is NOT a 70's muscle car, IMHO
Old Apr 24, 2013 | 02:08 PM
Dr. Tune's Avatar
2003 S600
I certainly agree that the S is not a 70's muscle car and shouldn't sound like one, IMHO. Which is why I'm planning on keeping the stock mufflers as the reduce noise and shouldn't hurt performance.
I guess that leaves me wondering why you deleted yours and are keeping the cats. Is it because you have already removed them?
My plan is to delete the cats and add a single larger oval mid-pipe through the Trans tunnel as it is beneficial to add an x-pipe, H-pipe or shared chamber pipe as close to the engine as possible. Exhaust gases flow in pulses (picture ping-pong ***** flowing through the exhaust) and when the pulse reaches the x-pipe it sees a low pressure area as the exhaust has effectively doubled in size from there back.
High pressure always seeks low pressure.
A single oval (for clearance) 4" mid-pipe would flow better than twin 3" and would cost less and take up less space.
True 3" split duals with no merge will lose that effect.
Just food for thought. ;-)
Old Apr 25, 2013 | 05:42 AM
MRAMG1's Avatar
S600, GL450, GLC 43
My friend, thanks for the input, but I have been doing this for over 30 years now
And yes, the mufflers were thrown out for just a little noise, no power gain here. I just hated the idea that it was as quite as a prius
Old Apr 25, 2013 | 10:55 AM
Dr. Tune's Avatar
2003 S600
Looking forward to the post videos
Old Apr 25, 2013 | 01:28 PM
MRAMG1's Avatar
S600, GL450, GLC 43
Will do
Old Apr 28, 2013 | 07:42 PM
sakodik's Avatar
E-Class
Me too! I need videos before I do this to my 65. Did you use your stock tips?
Old Apr 29, 2013 | 09:05 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Oh yeah, I didn't want the wife or any unsespecting pray to know she has been altered.
Until they here her roar from behind
