Tie rod plus
This might be somethig else as well.Well i was driving this week end and while i stopped in parking lot smelled something strange like burning something. And it is coming from my car. I checked and it is not coming frim engine compartment so i got on the ground and it got stronger underneath car. I have no clue if what it could be. Thanks guys
Jack up the car and test the wheel by hand trying to 'steer'. If it feels loose or knocks, the tie rod end is likely the problem. But I woud investigate further the mounts.
The smell can come from some road grime you picked up and now burning on the exhaust, if so it will go away. I had such an affair with a plastic bag.
Worse if you have a transmission oil leak dripping on hot parts. Must be checked.
Thanks for the respose.... The driver side tie rod is bad i checked it yesterday i am thinking i should change both inner and outer tie rods on both sides to make everything new.
Is there a way i can check motor mount before i take it to my mechanic???
Ok i will check for tranny leak i never though about than.... Thanks man i will keep the forum updated on progress because i am doing some work on car;
1 new rotors and pads
2 tie rods inner and outer on both sides
3 vale intake seals replaced
4 new tires
5 cabin filter and charcoal filter
6 oil change
( possible motor mounts replacement if needed?)$$$$$$$$$
The inners were also OK.
Generally they say you should change the pair, but in this particular case I did not see any reason to change the good one.
It is also true that the inners are cheaper, so it is not much of an extra cost to change those as well.
The engine mounts are filled with a jelly-like liquid, and it goes bad twhen the liquid leaks.
Check for the leak, it looks like water on the garage floor and it does not evaporate quick. If the mount is messy, it is probably leaking. Easier to check on the hoist where they can lift the engine block and extra half inch.
