Engine shake due to loo low rpm
Old Jun 1, 2013 | 01:18 AM
2001_clk430's Avatar
CLK430
My engine shake when driving for awhile then stop at a stop light it start shaking a little bit due to really low rpm around .5rmp. I want to raise up the rpm a little bit when the car is not moving, how do I do that? Can I do it myself?
Old Jun 1, 2013 | 07:23 AM
vmystikilv's Avatar
Range Rover
If no check engine light, then it's the transmission or motor mounts
Old Jun 2, 2013 | 01:08 AM
tusabes's Avatar
Mercedes
500 rpm is normal
If you have shake , you either face a misfire or bad mounts . Fix those (the problem ) and you will cure the symptom (shaking)
Just raising the idle will not fix the problem
