MY S430 Looks Like A Drag Racer HELP REAR SUSPENSION STUCK HIGH!?!
Old Jun 12, 2013 | 06:36 PM
matthewjames198's Avatar
04 s430 4matic
I was checking my left side front suspension today on my 2004 s430 4matic cause it was sitting alittle low so want to check for air leaks make sure the compressor was working etc. So i jacked up that side of the car and found nothening. But after lowering the front of the car I realized the rear suspension was sitting kind of high so I figured maybe once I start the car the system will level off. I was wrong when I started the car the rear went even higher and now its as high as its capable to go and the front is as low as it can go so now the car is completely undrivable. I tryed everything I can not get the rear to go back down? At least before the front left was a little low but it was drivable. Any ideas? Does the system need to be reset? Thanks
