CD Changer: "Device Unavailable" - manual eject of magazine?
Whilst switching between CDs today I got a "Device Unavailable" flash up on COMAND and now get no music played from anything in the CDC. I did a quick search and didn't see anything referring to a Device Unavailable warning.
I have a feeling that a CD has got stuck in the system but am unable to get it out. Had a little tinker with it but didn't want to make things worse. When I press the eject button there is a beep but nothing much seems to happen then. Is there a trick to getting the cartridge/magazine to eject? Wasn't sure if there was some kind of manual eject feature.
Thanks!
Thanks!
The magazine eject is done electrically - no power, no ejection. Perhaps faulty fuse, perhaps audio system or changer needs a reset...
How would I reset the changer?
Nice! I'll try that when I'm at the car next, thanks!
CD Changer
I am new to this forum. We just inherited E320 2004. Says we have CDC - five or six discs. Can't figure out how to insert. Got one in ------ but no more.
Where is CD magazine?
I managed to sort mine out. A slide a credit card in the gap all around the CDC magazine and it didn't appear to do anything but a few seconds after I removed it it bleeped and then slide out with all six discs in the little holders. I removed each one then replaced them and put it back and everything seems A-OK now.
Welcome! You'll want to check out the W211 forum.
https://mbworld.org/forums/e-class-w211-20/
"Where is CD magazine? "
Look in the trunk for a small turnbutton release on a door in the trunk lining. Inside, you should find the CD changer. There is a small button just below the magazine - push it, and the magazine should pop out. Note which way the magazine goes in!
Pull the small plastic hooks on the open side of the magazine to insert CDs. You can often find extra magazines on eBay. You can burn audio CDS on your computer to make your own mix of tunes, and to fill the CD for longer play. While you can try, it isn't likely to be able to play MP3 CDs.
