help! 2004 S55 sirius and bluetooth help.. definitive thread i hope!
Hey guys.. I have googled... searched the threads for days trying to figure this out.. seems like a lot of threads get hijacked and not answered or misinformation
so here is my setup... 2004 S55 with V60 phone connector mounted in armrest.. with Sat button on the comand radio unit, but no SAT box..
SIRIUS: what box do i need?? i have read so many threads of different boxes working on this model? one post said this box works A 211 870 33 89 but others say it will not.. is there an EXACT model box I need for this model of car i have?? and what elese is needed.. it is prewired for sAT
BLUETOOTH: I read that the 2004 is a strang model cause the standard dongle will not work with this? part B67875856... is part
B67875855 with the tail the only part that will give me bluetooth?? also i heard tale of BMW dongles working or any non-OEM solutions... PLEASE confirm exactly what i need
I REALLY need help with my exact model only.. if you have experience with this lmk.. i assume the S430/s500/s600/s55 all would use the same thing if it has the same setup as mine
Thanks guys
Thanks guys
you will need the puck with the tail and mobridge make a bluetooth kit for your car and i think you can add sat. that is the easiest way, look for argos which can add bluetooth but very hard to find.
'96 SL600, '05 S55 AMG, '06 C230
Zerodegre - Regarding the Sat installation, there is more to it than just the 'box'. Antenna (aka Trunk Tumor), etc. The installation is straightforward. I have been researching install on my 05 S55 and I have the official procedure. As for the kit, this is tricky. In their infinite wisdom, MB did not keep the kits consistent across model years, or even models within a MY. Your local MB parts guys will have a cross-reference guide to get you the exact part number. You don't have to order from them, just get the kit number. If you need help, PM me with your VIN and I can check your situation with my wholesale guys.
Cheers,
Jeff
PS - I can also check in the Bluetooth puck.
Cheers,
Jeff
