White ABC malfunction warning
I'm wondering if a weak battery could cause this. It sure seems electrical in nature.
What do you think?
It is almost surely electronic, the battery looks fine as it tarts the engine OK, but apparently the sensor network, the SAMs are not getting consistent power.
But, I got lots of other malfunction scares at the same time, and some electronic options simply stopped working.
A new battery solved all the problems.
It is always a good idea to start the trouble shooting there.
After filling with new fluid and cycling the system up/down about 20 times, I haven't had the warning in over a week and the fluid is still nice and light green/clear. I plan on doing another fluid and filter change in a couple weeks in order to minimize the amount of contaminants left in the system. If I can remember to, I'll take a picture of the old fluid and compare it to both the first flush fluid and new fluid to show how much crud can build up even in an ABC system that is functioning properly. For anyone doing this method, it takes exactly 2 liters to refill the resevoir. And now that I think about it, I haven't gone back to check the ride height after the fluid/filter change, so I'll have to do that tonight and report the findings.
Had the battery tested and it tested good.
Any other suggestions?
