S500 Tail light problem
Old Jan 4, 2014 | 08:36 AM
mklm83's Avatar
2000 Mercedes S500
Just purchased a 2000 S500 and the driver side left tail light is not functioning at all. Passenger side is fine. Bulbs replaced. Any suggestions?
Old Jan 4, 2014 | 10:25 AM
Critter's Avatar
07 E63 + 07 CLK63CAB
Seen others with issues on grounding, apparently the brown wire melts at the bulb holder, check carefully where the wires go into the taillight, on both sides. Hope it works. If all looks okay, try grounding from the bulb holder to the car body, next test for power on the offending light.
Old Jan 4, 2014 | 01:36 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
any other issues? check fuses!
Old Jan 11, 2014 | 02:08 PM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
There are no fuses for the lights in the W220. They are electronically protected. Check the wiring if voltage is present
Old Jan 24, 2014 | 03:22 PM
FrankBoni's Avatar
2005 S500 4 Matic
had a light go out, turned out to be the contacts needed a slight adjustment, they were intermittent. mechanic tweaked the contact to make full contact, all done. Bulb was still good.
