Airconditioning compressor kick on
Old Jan 9, 2014 | 03:33 PM
hhammoud57's Avatar
s600 2001 & 560 SL 1988
Cool Airconditioning compressor kick on
I have an S600 2001 only 60K miles.
My A/C is driving me crazy. when I start car it blows air but compressor do not kick start until I drive hardly for 2-3 miles after 15-20 min of drive it stops again.
I checked the errors it gave 1269 which I deleted but still the same or worse.
where is that bus multifunction sensor noting that I have checked the Freon r134a level 3 times in 3 different shops all confirmed it is right.
Any help please?
Old Jan 10, 2014 | 05:05 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
The compressor has no clutch, it runs full time. Regular AC shops checking pressure don't always know this. Search the forums.
Old Jan 11, 2014 | 12:12 AM
hhammoud57's Avatar
I went thru the forums many times. but simply do u mean my compressor is gone? If so this would be my problem change compressor right?
Thanks.
Old Jan 11, 2014 | 12:25 AM
hhammoud57's Avatar
or is it the sun sensor?
Old Jan 11, 2014 | 03:28 AM
benz_addict's Avatar
V12TT
Best would be is to run a scan and see if any codes are stored in the ACC module via STAR SDS and then go from there...
Old Jan 11, 2014 | 12:06 PM
kraut56's Avatar
Thanks.
You mis-understand; the MB compressor, unlike other car compressors, has no clutch to cycle on-off; the compressor is driven full time. There is a solenoid valve instead, that meters the coolant according to the computer.
If people ignorant of this feature try to test the ac the conventional way, they will get false results. Under some conditions, the system has to be reset for charging.
As others have indicated here, you should get the codes read; either with a DAS system, or from the ac control panel on the dash.
My thought at this moment is that it is overcharged.
Read, read, read!
Good luck!
