Just converted my ABC Suspension to Strutmasters Coil Overs
I have an issue with this right now. I did the strutmaster conversion on my 2001 s600 couple weeks ago and i'm happy with the ride. But a week ago the ps pump went and i can clearly see it leaking there. Strutmaster assured me before i bought the kit that i wouldnt need to change the pump and i'll be calling them about this but at this point i do need to replace it. I wanted to avoid a repeat so im looking into fitting in the standard ps pump from an airmatic but Im not sure if it'll fit fine. The pulley is different and so is the belt that'd go with it.
Does anyone have any experience with this? I'd really appreciate the help
The reason why your old pump died is because it had no fluid in the ABC section of the tank.
I looped the lines and topped up the fluid but there was a leak one where I guess so the tandem pump failed.
I went to a local hydraulic shop and they're fabbing up a small hose to make up for the space difference...we'll see how it goes
Sounds like the two of you need to get in the same shop, and have them swap your suspensions around, Doe.
the stance remains the same, as I used ride height links to set the height to my needs, and the system accepts the ride height as normal, very simple to do.
Having said and done this, I’m sitting with 240,000 miles on the clocks, and going strong. Have a gently used set of Yellow Speed Coil Overs for sale, if anyone is interested.
W220 S500
W220 S500
W220 S500
04 W220 S500
20" wheels btw
