Do you need to program a door control module?
Old Apr 22, 2014 | 05:12 PM
Jeff_S500's Avatar
2000 S500
2000 S500.. I am going to buy a door control module on ebay. If the part numbers are the same will I have to program the new DCM with SDS or should it work as is? All functions on my current DCM work except for the window switch.. when I scanned it with SDS at my shop it told me that "The power window actuation is faulty. The relay in componant N69/2 (Right door control unit) does not operate" Any help would be greatly appreciated!
Old Apr 22, 2014 | 09:10 PM
jnash's Avatar
2017 S63
I doubt it but as long as you have SDS then you can initialize the door module with it if it requires it.
Old Apr 29, 2014 | 01:50 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
sounds like the windaow motor. not dcm,
Old May 4, 2014 | 04:00 PM
Jeff_S500's Avatar
2000 S500
Finally got around to putting new DCM in today. Success! Window now works as well as all other functions of the DCM.. No need for SDS..
