WHEELS OFFSET
Old Apr 26, 2014 | 10:06 AM
hotgreek's Avatar
2004 S 55 AMG
WHEELS OFFSET
Any ones knows the wheels offset foe a 2000 S 500 ? Wheels with 35 offset will they fit on it without any problems ?
Old Apr 26, 2014 | 10:46 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
You might find some information here that will help you. http://www.benzworld.org/forums/w215...l-offsets.html
Old Apr 26, 2014 | 11:17 AM
mcguirja's Avatar
Mercedes SL63 AMG; Mercedes E63 AMG S 4matic; Mercedes C43 AMG; Mercedes S Class, Mercedes GLK
Stock wheels for your model are 7.5"x16" with 46mm offset - source MB USA Owners Manual: https://www.mbusa.com/vcm/MB/Digital...55amg_s600.pdf
If you use the width offset calculator on the forum located here: https://mbworld.org/forums/tire_rim_calculator.php it will tell you the difference in fitment. In this case when I ran your numbers through, assuming you are staying with same wheel and tire size, it provides you with 11mm more clearance on the inside, but would extend the outer clearance by the same amount. 11mm is about half an inch, so this is a long way of saying you should have no problem with this offset but encourage you to look at your car for clearance to confirm half an inch won't make a difference. Should only be an issue if you've lowered your car significantly.
James
Old Apr 26, 2014 | 09:36 PM
hotgreek's Avatar
2004 S 55 AMG
the problem is that I bought a set of Mandrus menheim 19 x 8.5 and 19x 9.5 from ebay state it that will fit in my 2004 S 55 AMG but the rims have 35 offset and rubbing the rear bumper some times .I want to sell it to my friend that he owns a 2000 S 500 and I want to make sure they will fit in his car without any problems
Thank you for the intel
Old Apr 27, 2014 | 01:57 AM
tusabes's Avatar
Mercedes
Big rims require a tab on the rear bumper be trimmed . Any good custom wheel shop can do this
Old Apr 27, 2014 | 07:51 AM
vmystikilv's Avatar
Range Rover
I have the same size 19 and there actually true AMG wheels. Just roll your fenders and you'll be fine . By the time I got a moment to do it my car had did it for me, lol
Old Apr 27, 2014 | 09:22 AM
mcguirja's Avatar
Different Size Wheels require more than just the offset calculation
You are also using considerably wider and larger diameter wheels, which changes the equation considerably. The width offset calculator will give you the variances if you plug in all the info. You can determine what size tires are required to maintain the original diameter as well.
Old Apr 29, 2014 | 01:42 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
the 35 off set should fit, the only problem i see is that the lug nuts might be a little to long,
